Copyright
http://www.cliodci.net
65 bhp -
No blue letters in the word DCI on the sidestrip.
No intercooler.
Turbo is a 5435 970 0000 Borg warner K series.
JB3 gearbox pretty much same as 1.6 16v.
Engine codes - K9K 704, K9K 700
OVAL PLATE CB07 (Inside of drivers door)
Standard Turbo Boost Pressure = 1 Bar (14.5psi)
Standard Fuel Pressure = 1400psi
No intercooler
80 bhp -
Blue I in the word DCI on the sidestrip.
Large Intercooler located infront of the radiator.
Injectors 15% more efficient than 65's.
Slightly different turbo to 65 (5435 970 0002 Borg warner K series).
JC5 gearbox pretty much same as 2.0 16v. From 2004 onwards JH3 and JR5 boxes were also fitted.
Engine code - K9K 702
OVAL PLATE CB08
Standard Turbo Boost Pressure = 1.2 Bar (17.4psi)
100 bhp -
Blue CI in the word DCI on the sidestrip.
Small fat intercooler (17% more efficient than 80 ic). Located infront of the radiator at the bottom.
Same injectors as 80.
Same fuel pump as 65 & 80 but runs at 1600 bar
Again, more efficient, variable geometry turbo (5439 970 0030 Borg warner K series)
Different block and head and different injection set up to 65 & 80 with the 100 having a stronger crank, stronger rods and pistons.
Inlets on the head are bigger, different cam and ex manifold.
Gearstick, reverse is down and right as opposed to up and left with the lift.
Gearbox is a JR5 120. (5 Speed box as fitted to petrol lagunas, no renault 6 speed box fits!)
Engine code - K9K 712.
OVAL PLATE CB2G
Standard Turbo Boost Pressure = 1.25 Bar (18.1psi)
Standard Fuel Pressure = 1600psi
Misc -
The reason the Pistons were changed on the dci 100 was due to the extra fuel pressure causing issues with the 65/80 pistons - worth noteing if you plan on changing fuel pressure
The dci 65 and dci 80 turbo is good for 1.5 bar but the dci 65 will NEED an intercooler to reach these sort of figures reliably and really the dci 80 will need a dci 100 spec intercooler at least too!
The turbo repair kit for the all the dci turbos is the Borg Warner KP35 kit
A handy list of turbo part numbers and oval plate numbers which correspond to the mentioned vehicles. These turbo's do fit other K9K variations ( of which there are over a hundred ) the oval plates are just rough guide lines to help you on the Dialogys. The part numbers given are the Borg Warner number ( k series ) and not the Renault part number. The Borg warner part number can be found on the blower housing ( blue / yellow / red badge )
Engine type turbo part number model / oval plate
K9K 700 * 5435 970 0000 * Kangoo FC07
K9K 702 * 5435 970 0002 * Clio CB08
K9K 704 * 5435 970 0000 * Clio CB07
K9K 710 * 5435 970 0000 * Kangoo FC09
K9K 712 * 5439 970 0027 * Clio CB2G
K9K 714 * 5435 970 0011 * Kang FC1E
K9K 718 * 5435 970 0012 * Clio CB3N
K9K 722 * 5435 970 0002 * Meg CM0F
K9K 724 * 5435 970 0012 * Sce BM1F
K9K 728 * 5439 970 0027 * Sce JM02
K9K 732 * 5439 970 0030 / 0070 Meg CM1E
K9K 740 * 5435 970 0011 * Clio CB3M
K9K 750 * 5439 970 0000 * Clio CR0V
K9K 764 * 5439 970 0030 / 0070 Clio CR0H
K9K 766 * 5435 970 0012 * Clio CR0F
K9K 768 * 5435 970 0011 * Clio CR0G
K9K 780 * 5439 970 0030 / 0070 Lag BT0A
K9K 802 * 5435 970 0012 * Kang FW0B
K9K 804 * 5439 970 0030 / 0070 Kang FW0C
K9K 706 * 5439 970 0030 / 0070 Kang FW0F
K9K 832 * 5439 970 0030 / 0070 Kang BZ0B
