I have a Series 2 19. The brake pads and the discs have been replaced and im still seeing the flashing light on my dash. Does anyone know why, how to fix this?
Hi there, could u please give more details here, I'm not sure if I really get this.
There should be a wire connected to the brake pads. This is to warn you if the pads need to be replaced. Check if this wire is connected as it should. Also check if it ain't damaged and makes contact with the chassis wich would light up the dashboardlight.
if you need more details, just let me know
[ This message was edited by: Mclain on 2002-01-13 14:19 ]
I have visually checked the cable and it looked ok and i have changed the pads and discs.
I might have to have a look at the cables again.
there must be a better way than ripping out the cable? I want to fix the light not disconnect it....
Offcourse the best way to find out where the probem is in the wiring, is using a multimeter. Proberly the wire is damaged somwhere (almost always near the break)You van replace the wires for sofar you can see them. (they are pink) Maybe this wil help.
