Renault clio Adjustable Power Boost???
MarcoG
Vriend van mij vroeg zich af of dit kon werken???
http://www.speedydelivery.co.uk/car-tun ... clio.shtml
Dit is hoe het zou moeten werken...maar volgens mij is het de reinste kul!
The Renault clio Adjustable Power Boost - A fully adjustable resistance unit enabling you to boost the power output of your Renault clio. This dashboard / console mounted variable controller will allow you to adjust and increase the fuel flow into your Renault clio engine. Suitable for all cars equipped with electronic fuel injection. Our Adjustable Power Boost fools your cars computer into thinking that your Renault clio engine is sucking in air at a lower temperature, hence the timing is advanced. Timing advance helps produce more power by igniting the sparks sooner, providing more time for the fuel / air mixture to burn completely, increasing cylinder pressure, thus providing more power.
Erik Olijnsma
is al vaker besproken,
en het werkt 100%, niet dat je meer vermogen krijgt, maar wel vaker bij de pomp staat :D :lol:
