Hoe snel???
RO 16v
Sorry dat het in het engels is maar hier een voorbeeld wat acceleratie is.
A lesson in acceleration:
First, some useful info:
* One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower
than the first 4 rows at the Daytona 500. (+ 7000 hp :p )
* Under full throttle, a Top Fuel dragster engine consumes 1œ gallons of
nitro methane per second; a fully loaded 747 consumes jet fuel at the same
rate with 25% less energy being produced.
* A stock Dodge 426 Hemi V8 engine cannot produce enough power to drive the
dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the
fuel mixture is compressed into a near-solid form before ignition.
Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame
front temperature measures 7050 degrees F.
* Nitromethane burns yellow. The spectacular white flame seen above the
stacks at night is raw burning hydrogen, dissociated from atmospheric water
vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an
arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way,
the engine is dieseling from compression plus the glow of exhaust valves at
1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in
the affected cylinders and then explodes with sufficient force to blow
cylinder heads off the block in pieces or split the block in half.
* In order to exceed 300 mph in 4.5 seconds dragsters must accelerate at an
average of over 4G's. In order to reach 200 mph well before half-track, the
launch acceleration approaches 8G's.
* Dragsters reach over 300 miles per hour before you have completed reading
this sentence.
* Top Fuel Engines turn approximately 540 RPM's from light to light! This
one confused Stan, but stop & ponder the fact that the engine is only used
for apx 4 to 5 seconds.
* Including the burnout the engine must only survive 900 revolutions under
load.
* The red-line is actually quite high at 9500 rpm.
* The Bottom Line; Assuming all the equipment is paid off, the crew worked
for free, and for once NOTHING BLOWS UP, each run costs an estimated
$1,000 per second. The current Top Fuel dragster elapsed time record is
4.441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top
speed record is 333.00 mph (533 km/h) as measured over the last 66' of the
run (09/28/03 Doug Kalitta).
Putting all of this into perspective:
You are riding the average $250,000 Honda MotoGP bike. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the RC211V hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph (293 ft/sec). The 'tree' goes green for both of you at that moment. The dragster launches and starts after you. You keep your wrist cranked hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds the dragster catches and passes you.
He beats you to the finish line, a quarter mile away from where you just
passed him. Think about it, from a standing start, the dragster had spotted
you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot (402 m) long race course.
That, folks, is acceleration.
Tja wat valt er nog te zeggen. :worship: :worship: :worship:
Jasper16v
Dat laatste stukje, geweldig (Y)
canonballman
ZEER interessant!
Begrijp alleen niet helemaal wat hiermee bedoelt wordt.
leuk stukje idd, maar eigenlijk meer ACT. Effe verplaatsen dus Ro! Dit topic wordt gesloten
