[img]http://i135.photobucket.com/albums/q137 ... turbo2.jpg[/img]
[img]http://i135.photobucket.com/albums/q137 ... gturb2.jpg[/img]
[img]http://i135.photobucket.com/albums/q137 ... ICfnt2.jpg[/img]
[img]http://i135.photobucket.com/albums/q137 ... plate5.jpg[/img]
[img]http://i135.photobucket.com/albums/q137 ... build2.jpg[/img]
F7r is originally from the clio williams, but this is the 714 version which is the Megane 16v homologation item for the Maxi kit cars, hence the block is 30% stiffer but 6kg lighter, which is nice. Even so i have done a lot of strengthening on the bottomed, with a 12mm steel plate and machined from solid crank bearing caps effectively turning the bottom end into a ladder frame style assembly, and then further stiffened by a machined from solid dry sump plate.
[img]http://i135.photobucket.com/albums/q137 ... 180154.jpg[/img]
[img]http://i135.photobucket.com/albums/q137 ... 180162.jpg[/img]
[img]http://i135.photobucket.com/albums/q137 ... studs4.jpg[/img]
518bhp megane F7R 714..
Just Awesome. I just want to see more of it
Holy worship.
cool
too bad i dont have a money tree in mij garden
omg i'm spraying cum everywhere!
Awesome machine!
zit net effe dit topic door te spitten.
niet normaal
niet normaal
http://www.barmartechniek.nl
Erg dik!
Hier wat meer info: http://www.seatcupra.net/forums/showthread.php?t=104938
Zou hij ondertussen al wel gereden hebben? Ik mag het toch hopen!!
