Jajajajaja
Ik heb de foto's... maar ik moet eerst wachten tot Merijn weer bijgekomen is van een coma
zodat hij ze online kan zetten
Nou, daar komen ze dan...
Het zijn 27 in totaal, dus ga maar ff schijten of zo. Als je terug bent zullen ze wel geladen zijn.
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit01.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit02.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit03.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit04.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit05.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit06.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit07.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit08.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit09.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit10.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit11.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit12.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit13.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit14.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit15.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit16.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit17.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit18.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit19.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit20.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit21.jpg[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... ruit22.jpg[/img]
Foto's zojuist gekregen van Patrick!
[img]http://members.home.nl/m.vandekamp/GTTu ... rick01.JPG[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... rick02.JPG[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... rick03.JPG[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... rick04.JPG[/img]
[img]http://members.home.nl/m.vandekamp/GTTu ... rick05.JPG[/img]
Mods: kan de topictitel aangepast worden? Thanks!
Ziet er niet al te ernstig uit. Gaat helemaal goed komen
Ziet er netjes uit! maareh merijn..jij hebt de hele dag zitten kijken en aanwijzingen gegeven? zie je nergens druk bezig laat staan dat je vieze handen hebt gekregen
goed bezig hoor
goed bezig hoor
merijn, johan, tom, eric: Mooi werk!
ow..tom doelde op jou met de foto's makenMerijn schreef:Tom? Welke Tom?
dacht datie zichzelf bedoelde!
haha... Nee, Tom was er niet bij.
Met z'n 3'en was voldoende. Je loopt elkaar in de weg als je niet uitkijkt. Maar nogmaals moet ik mijn complimenten geven aan Erik en Johan! Echt superrelaxed, hoe die gasten aan het werk zijn gegaan!
knap dat je dat van daaruit kan bepalen...Abel schreef:ziet er idd prima uit. Gewoon goed schoonmaken roest ff met een fijn schuurpapiertje weghalen en de kop licht vlakken.
prima tedoen.
als het op die manier opgeknapt moet worden dan moet Merijn hem ff bij iemand anders brengen
tja. ik ga er van uit dat het verder aleen een lekker koppakking is en dat de rest gewoon goed is.
het blijft een c blok he dat gaat bij goed gebruik niet stuk.
die cylinders zien er verder goed uit en de speling lijk ook niet enorm.
Ik weet niet wat er allemaal mis mee is, maar ik ga dit blok niet terug hangen als alleen de koppakking is vervangen. Ik wil het risico niet nemen dat ik straks weer met gezeik zit, dus wil ik het in 1 keer goed hebben.
mmm...en die verticale "hoonnerven"??? (Abel schreef:tja. ik ga er van uit dat het verder aleen een lekker koppakking is en dat de rest gewoon goed is.
Of kun jij met jouw ogen op de honderste mm nauwkeurig van een foto de zuigerspeling 'meten'
Straks krijgen leken hier nog het idee dat een motor reviseren niets meer is als een beetje poetsen, lichtjes schuren en opnieuw spuiten.
Dat zijn oliekanalen die een goede zuigersmering bevorderen, dat moet jij toch weten als revisie monteurPtrGte schreef:
mmm...en die verticale "hoonnerven"??? ()
Sorry Reinier, ik doe gewoon net alsof, ik reviseer die dingen ook gewoon met een schuurpapiertje hoor
Laatst gewijzigd door PtrGte op ma 24 jan 2005 10:42, 1 keer totaal gewijzigd.
oke!
ja ok. je wilt weer rijden met die motor of je wil een als nieuwe motor dat is natuurlijk een groot verschil. Ik wil ook niet als revisie deskundige optreden. Ik wilde alleen zeggen dat dit blok nog niet "op" lijkt.
"most bang for the buck" principe werk ik liever mee
Zit wat in, ja...
Ik doe liever meteen iets helemaal goed, zodat ik er (hopelijk!) de rest van zijn leven plezier van kan hebben. Het kan zijn dat ie met een nieuwe koppakking best weer een hele tijd vooruit kan, maar ik wil het risico niet nemen. Ik weet ook niet hoeveel het blok gedraaid heeft. Er staat 164000 op de klok, maar die klok doet het niet meer.
Wordt het blok gereviseerd en origineel gehouden, of ga je er ook nog wat aan veranderen/tunen?
Goed bezig in elk geval
Gr, Frits.
Gr, Frits.
ja merijn, wat gaat er allemaal met t blok gebeuren? of is dat voor jou ook nog een verrassing?
In principe blijft hij gewoon standaard, maar wie weet komt Patrick wat leuks tegen en maken we er een 1.6je van of zo.
Maar dat zit niet in de planning.
Een sterkere koppakking en sterkere kopbouten wil ik wel graag. Maar dat is geen tuning.
hmm 1.6 Turbo klinkt wel leuk...doe es gek zou ik zeggen merijn (en patrick)
boring 80 maakt iets van 1548 cc ja, maar ik had al wel gezien dat dat aardig groot is...Steven schreef:1559cc is het max wat eruit kan...
Das de inhoud waar de maxi's mee reden, maar dan zijn de cilinderwanden zo dun dat het gewoon geen vertrouwen meer kan wekken
Een geflowde kop heb je meer aan...
we kenne altijd nog ff kijken of er een of andere langere slag krukas te verbouwen is natuurlijk
