Renault 19 16S Turbo made in Brazil
Hello Guys..
Im finish my engine F7P 1.8 16S Turbo.
Look the last photos, more photos in my site http://www.renaultclub.com.br found in howto forum.
Brazilian Turbine Master Power .42/.49 with wastegate
[img]http://www.renaultclub.com.br/modules/c ... CF0211.JPG[/img]
My engine engineer - Bambam and yours creator!!/b]
[img]http://www.renaultclub.com.br/modules/c ... CF0212.JPG[/img]
Motor F7P Turbo from Brazil project
[img]http://www.renaultclub.com.br/modules/c ... CF0216.JPG[/img][/img]
Hi Calle, yes it goes to fit, I struck a little the safe of the engine to fit the turbine. ehee. A little. its a good service !!!
After In post a new photos the safe.
Igor
Igor
ehehe Im promesse. I will make a video of my engine. hhee ..
Wow that looks really great
Good work overthere
Good work overthere
Hey, I told you thatMartijn. schreef:i wanna see the pictures when you'r going to fit it in your R19, looks like it doesn't fit.
I took a look at how the outlet manifold is placed in my 19 (and Martijn his 19
Various company's (like http://www.k-tecracing.com ) sell turbo-manifolds witch are smaller then the original manifold. Why not use a similar to that one.
I also heard that the outlet manifold of a volvo turbo should fit the enginge, but I'm not sure (never tried).
I sure hope it fits
Hi Guys.. I make a New Hole in my safe.
look
[img]http://www.renaultclub.com.br/modules/c ... CF0228.JPG[/img]
With a this new space My turbine is fit !!!
This weekend I will post a engine mount in car.
Igor
look
Igor
Hello. Nice project, but i have some questions
do you have somthing to protect the car from te heat that radiates from the turbo?
and is your turbo welded to the mainfold?? if yes, are you not affraid that the welding wil break?
And how did you lower the compression?
Hi Abel,Abel schreef:Hello. Nice project, but i have some questions
1- Yes, The turbine is welder to the manifold.
2- I will go to cover the brake and the safe with termica blanket, and will cover the turbine too with termico insulator
3- Im lower the compression changed piston and knuckle. (undestand) ?? My tax is 6,5:1 and Im use Alcoll Fuel
Igor
Turbine is welder to the manifold
NEw Piston and Knuckle by VW AP 2.0 82,5mm
[img]http://www.renaultclub.com.br/r19/usuar ... ase3_2.JPG[/img]
My new TAX the piston is 6mm under block.
[img]http://www.renaultclub.com.br/r19/usuar ... ase4_2.JPG[/img]
Hey MartijnMartijn. schreef:i wanna see the pictures when you'r going to fit it in your R19, Jeroen.k says it doesn't fit.
Its FIT !!! Look ! Under my car..
[img]http://www.renaultclub.com.br/modules/c ... CF0271.JPG[/img]
This week, I will make a new scape 3'' !!!
and Over my car
[img]http://www.renaultclub.com.br/modules/c ... CF0277.JPG[/img]
This Week, I will make a pressure pipes..
Wow that is a tight fit
I hope the clearances are big enough so the turbo wont hit anything when the engine starts moving when you rev it.
A great piece of work though
And a crafty spot of welding, welding together two cast iron parts. I wonder if that will hold under the stress of heat and vibration...
Did you use special engine mounts to cope with all this power? I understand than the normal R19 engine mounts are allready to weak on a standard 16s, so they might not last very long on a car like this.
Looking forward to the movies
6,5:1 compression ratio? Even with alcahol fuel this is very low. I suspect even too low. Non boost driving will suffer from this compression ratio.
The turbocharger fit is the worst "engineering" solution I've seen in years. Welding of cast iron? I doubt even the standard manifold will sustain turbo operation.
Air intake in that position is an engine killer. Too much dirt and dust pick up.
Your steering rack won't like a very hot turbocharger (even with insulation) up on top.
It'll probably hold for a while but I doubt this setup will survive extensive operation. Even under relatively light load conditions.
I tried to tell you via PM, e-mail and msn you made a few errors of judgement. But you'll find out yourself. I hope to speak you in a year or so with an update on your vehicle.
Give the man a break...speedline schreef:6,5:1 compression ratio? Even with alcahol fuel this is very low. I suspect even too low. Non boost driving will suffer from this compression ratio.![]()
The turbocharger fit is the worst "engineering" solution I've seen in years. Welding of cast iron? I doubt even the standard manifold will sustain turbo operation.![]()
Air intake in that position is an engine killer. Too much dirt and dust pick up.![]()
Your steering rack won't like a very hot turbocharger (even with insulation) up on top.![]()
It'll probably hold for a while but I doubt this setup will survive extensive operation. Even under relatively light load conditions.![]()
okay, there are some things You and I would do different, but at least he tries to manage it...
there are lots of guys in this "world" who only dream and speculate on the "turbo-item" but there aren't many guys who really manage it...
so, from my point of view...good job!!!
PtrGte schreef: Give the man a break...
Ok, I'll give the man a break and see him waste his money.
Why don't you tell him then?PtrGte schreef: okay, there are some things You and I would do different, but at least he tries to manage it...
True.PtrGte schreef:there are lots of guys in this "world" who only dream and speculate on the "turbo-item" but there aren't many guys who really manage it...
From my point of view it's wrong if you see fuck-ups in the making and don't point out these obvious mistakes.PtrGte schreef: so, from my point of view...good job!!!![]()
[PtrGte"]
okay, there are some things You and I would do different, but at least he tries to manage it...[/quote]
I already told him via MSN/PM that it was NOT very clever to built a 2.0 16v from an F3R block...
that's where it started a few weeks ago...
then he came up with the turbo idea...So i helped him with some info on REDUCING CR, but I didn't tell him to set it at 6,5:1 ... and so on...
I think it's a good thing that a few people try to do things that others will never do in their lifetime...so I will help as much as I can in those cases, but if somebody has a different idea of building an engine, then that's all right with me...
I agree that pointing out potential failures is correct, and I will do so, but It can be done in a nice way...PtrGte schreef: so, from my point of view...good job!!!![]()
oke back on topic...
Igor...are you sure you are running 6,5 : 1 ???
[5 minutes later]
uhm....oke, i did a little math over here, and the Compression ratio is indeed 6,5 :1 ...BUT i DID NOT calculate with the bowl depth in the piston as i can see on the pictures, so it will be approximately 0,5 lower...
this will result in 6.0 : 1
[5 minutes later]
Speedline,
At no moment Patrick said I to make my engine with 6,5:1 or 6:1. !!
If you find that she goes to be bad my engine! he waits to see the video and the test in the dynamometer.
If you finds that the things have that to be default. I'm NOT.
I and my preparador of my engine, we find that it must have this tax of compressao, to be able to use to 1,5bar in the turbo! This my turbine is special! thing that nao goes to exist in Holland and no place of the world! therefore Brazil manufactures turbine on order, not uses the standardized things equal ai. We are a very different people of the remaining portion of the world where we create, we innovate and we to perfect the things.
I am very grateful to Patrick for the tips that it gave to me on engine F7P! and I mounted turbo in my 1,8 Exactly engine F7P 16V.
Patrick, very obliged for the tips that you gave to me, half of the merit of this engine is its.
tks Igor
tks Igor
The Turbo's Used in Holland aren't exactly standard to...at least...the hybrid ones aren't.
You ar going to drive at 1,5 Bar and a compression this low...aren't you afraid you will have no power in low rpm (low compression and none or not much turbopressure.) and only a peak of power at a short range of rpm? Because the Turbo spins at a high pressure...
What did you do to upgrade the brakes and supspension of the car?
Sure, I put brakes more big and Brembo. My suspension I put another spring more low in Front and Read I will low too.jeroen.k schreef:The Turbo's Used in Holland aren't exactly standard to...at least...the hybrid ones aren't.
This turbine goes to give to be able to me in LOW and HIGH RPM. I already had thought about this. Accurately one of the reasons that I ordered to make the special turbine. I go to see if I find the map of the turbine and rank in the site
Ok I will post..jeroen.k schreef:I sure am curious about your dynojet spin!
That will prove your engine's capability...
Also I hope for you that it lasts for quit a time!
When I mount all pieces..
Igor
renault19_16S_Brasil schreef:If you find that she goes to be bad my engine! he waits to see the video and the test in the dynamometer.
tks Igor
renault19_16S_Brasil schreef:Speedline,
renault19_16S_Brasil schreef:Im lower the compression changed piston and knuckle. (undestand) ?? My tax is 6,5:1 and Im use Alcoll Fuel
I think you're misunderstanding the point that speedline's trying to make...the fact that you're using the standard exhaust manifold and the unfortunate position the turbo is in he's only pointing out major engineering faults in this turbo'd NA engine...it surprises me you're still using the standard manifold instead of welding a new one...including the fact you welded the turbo straight on! You could have at least made a flange; that alone would have upped reliability. I'm not sure how long this'll hold at 1.5Bar.
I don't see why you don't turn to the States for something like this...they're lightyears ahead of pretty much anybody but Japan as far as goes turbo'ing NA cars...just a thought of course.
This doesn't hide the fact you're working on a very interesting project; it's just a shame that you dispose of any form of criticism as a personal attack on 'Brazilian creative and perfectionistic innovators'
http://www.homemadeturbo.com/turbo_proj ... om-strike/
You might find this an interesting site, good luck.
Ola, AREXSTYLE, I could have done exhaust of the pipe. But I used exhaust the same because they, its very of being well made and very strengthened, is of double air flow, what me of more the force without the gases of the exhaust pipe if they collide in exhaust. I am developing one exhaust new to vender in a kit that I am mounting, I will mount in another engine and I will measure in the dino which exhaust is better. I made of proposito the 6,5:1 tax! to use alcool. Therefore he is very cheap in Brazil.
Igor
Igor
Hei Guys.. Look ! Im Finished..
[img]http://www.renaultclub.com.br/r19/usuar ... se5_01.jpg[/img]
[img]http://www.renaultclub.com.br/r19/usuar ... se5_02.jpg[/img]
[img]http://www.renaultclub.com.br/r19/usuar ... se5_03.jpg[/img]
[img]http://www.renaultclub.com.br/r19/usuar ... se5_04.jpg[/img]
This with 0,5 bar of pressure to soften the engine.
Igor..
Igor..
Hi guys.. The topspeed with 0,5bar is 240km/h in Painel of my car..
Next month, Im up 0,5bar for 1,5bar. put intercooler and messure in dyna..
Igor
Igor
Can you show movies how it runs? I am very anxious!
Anders ik wel.Erik Olijnsma schreef:Can you show movies how it runs? I am very anxious!
Show us movies.
Renault 5 GT Turbo "EVO"
I think your one of the fastest turbo-builders in the world...starting with NO-knowledge and within a few weeks your car is finished!!!
nice work man!
nice work man!
I have that to be thankful Patrick ! Tks For all having helped to construct this engine.PtrGte schreef:I think your one of the fastest turbo-builders in the world...starting with NO-knowledge and within a few weeks your car is finished!!!![]()
nice work man!
Igor
Wow really nice job mate!
