bought a GTE
Blue Mule
I BOUGHT IT!
[img]http://www.quartermile.ws/Riker/gte_a1.jpg[/img]
[img]http://www.quartermile.ws/Riker/gte_a2.jpg[/img]
It's mine...
My friend who works as an mechanic told me that the original GTE machine was devastated by previous owner so he put Volvo 440 engine in it, possibly 105 or 110 ks!
I have to check the engine out for some signs of it,cos I have to know what i have under the hood
I'll post some more pics these days, and the project will start. I'll focus on making the car as it was new, i will restore it and drive it old school just like in the good ol days (when i was 5 years old 8) )
Renault 5 Blue Mule
For as far as I know, it says VOLVO on the top of the engine, quite big... So that shouldn't be so hard to check! ;)
Nice car! (Y)
Joost (DoubleYou)
Car: 5 GTT, 5 GTS EBS
Nice! Looks like this car has its original GTE stickers on the side, you don't see that often!
Have fun with your car and keep us informed!
Gideon B
Nice car (Y)
Looks nice! :worship:
But, what country are you from?
Erik Olijnsma
I think Romania
isn't it Kroatia, looking at first picture
R(ay)Si
Nice car!
Good luck whit it (Y)
Alleen nog maar VW!
Blue Mule
Thank you guys! :worship:
THe mechanic said he put a Volvo engine (probably 440) 1.7 with 105 or 110 hp...
When i finish the car i'll go on rolling road to test it, so i can be 100% sure :D
P.S. - im from croatia
So...where to start? any volvo tuner that can provide me camshaft for my engine?! :smoke:
Renault 5 Blue Mule
djtheo
nice car... looks like i see my car 8) wish U good luck with the 5 gte... be carefull with your stickers, u don't see often those stickers on the side of the car... but i have them also still on my car :p good luck and sent more pics... are 2 my email... i like it!!!
Maybe you can post a photo of the engine, so we can find out what kind of an engine it is! :)
Have fun with it! (Y)
Mrtn
Car: R5GTT
Volvo got 2 types of engines with multipoint, not speaking about its turbo-engine...
a 1.7 with 95pk, just as Renault
and a 2.0 with 110pk. The engines look the same... so you have to check it by its enginenumber.
nice car btw
Mrtn = Maarten
Blue Mule
i think i have one of these engines...
Volvo 440 GLTi
Code
Manufacturer Renault
Type S-4
SOHC
8 valves total
2 valves per cylinder
Main bearings
Construction
Bore × stroke 81.00mm × 83.50mm
3.19 in × 3.29 in
Bore/Stroke ratio 0.97
Displacement 1721 cc
(105.022 cu in)
Unitary capacity 430.25 cc/cylinder
Compression ratio 10.50:1
Fuel system Renix fuel inj.
Aspiration Normal
Compressor type N/A
Intercooler None
Catalytic Converter Y
Max. output 110.5 PS (109.0 bhp) (81.3 kW)
@5800 rpm
Max. torque 140.0 Nm (103 lbft) (14.3 kgm)
@4000 rpm
or Volvo 440 GLE
Code
Type S-4
Wet sumped
SOHC
8 valves total
Main bearings
Construction aluminium alloy block & head
3.19 in × 3.29 in
(105.022 cu in)
Compression ratio 9.50:1
Aspiration Normal
Compressor type N/A
Intercooler None
Max. output
(DIN) 91.3 PS (90.0 bhp) (67.1 kW)
@5800 rpm
Max. torque
(DIN) 132.0 Nm (97 lbft) (13.5 kgm)
@3600 rpm
- bore & stroke are the same, capacity also...i think those are the same engines and one of them is used in my GTE
i'll do something around the car tomorow, and ill post some more pics
how much do stickers cost when ordered from renault!?
Renault 5 Blue Mule
Mrtn
Car: R5GTT
Mrtn schreef: The engines look the same... so you have to check it by its enginenumber.
I'm sorry, I made a mistake, there's a visible difference between the 2 engines, the 2.0L has the same inlet (inlaatspruikstuk, don't know the english word :wink: ) as the turbo engine :)
but then the text on the inlet is; 'elektronic fuel injection' or 'Volvo 2.0 Litre injection'
Mrtn = Maarten
Blue Mule
Renault 5 Blue Mule
Ad van Haperen
I Think you have the original Renault5GTE engine.
You can see some pics on my website:
http://www.renault5.nl
Volvo has used the same engines in the 400 series...so they can still be the same.
Ad van Haperen
O sorry i was thinking you wil see some differents but there isn't?
Volvo used standard better exhaustmanifolds, and some sensors and wiring could be different, but the 1.7 mpi engines are the same.
Ad van Haperen
never to old to learn i see :D
