(volgende is in engels omdat ik zowat alle forums gehad heb met de volgende topic. Blijkbaar weet niemand hoe dit moet.)
Hello,
I'm a noob on this forum and i'm trying to find out how to burn a MP3 disc for use in an mp3 car audio player. I've got several audiomixes (30 minutes) which i'd like to play without gaps between the trax but WITH indexnumbers so i can skip to the good parts without having to fast forward to it. The mix HAS to be in MP3 format, so no converting to WAV.
I've heard from .cue files and tried to make a cd (using subdirs) with a cue file like so:
[Megamix compilation]
| [Megamix 2000] --- [Megamix2000.MP3]
| \__[Megamix2000.cue]
[Megamix 2001] --- [Megamix 2001.MP3]
\__[Megamix 2001.cue]
The cuefiles for the [megamix2000] for example look like this:
TITLE "(Ultimate Megamix2000)"
FILE "Megamix2000.MP3" MP3
TRACK 01 AUDIO
TITLE "(Track 01)"
INDEX 01 04:45:13
TRACK 02 AUDIO
TITLE "(Track 02)"
INDEX 01 07:12:61
TRACK 03 AUDIO
TITLE "(Track 03)"
INDEX 01 11:31:26
TRACK 04 AUDIO
TITLE "(Track 04)"
INDEX 01 14:51:24
TRACK 05 AUDIO
TITLE "(Track 05)"
INDEX 01 19:02:05
TRACK 06 AUDIO
TITLE "(Track 06)"
INDEX 01 22:12:06
TRACK 07 AUDIO
TITLE "(Track 07)"
INDEX 01 24:50:27
TRACK 08 AUDIO
TITLE "(Track 08)"
INDEX 01 26:55:38
TRACK 09 AUDIO
TITLE "(Track 09)"
INDEX 01 30:12:26
I've put the cuefiles in the same directory on the cd as the corresponding mp3 file using same names.
When I burn this cd and play it in the car, it turns out that it plays only 2 track on the album :
Megamix 2000 (30 minutes nonstop)
Megamix 2001 (30 minutes nonstop)
Why aren't these files indexed by the corresponding cue files?
The 2000 mix alone should have 9 indexes.
Could anyone help me with this one?
I screwed up plenty cd-r's trying to fix this.
Greetz Raymond.
Grote mp3mix indexen voor mp3 speler auto?
Die cue-files werken inderdaad alleen als je meteen het cd'tje brand (muziek cd, geen MP3). Dus daar heb je niks aan.
Je zult alle MP3's moeten knippen, vrees ik. Of je brand een cd met cue-file en converteert deze weer naar MP3. Beetje omslachtig, maar zo krijg je wel wat je wilt.
SlimMerijn schreef:Die cue-files werken inderdaad alleen als je meteen het cd'tje brand (muziek cd, geen MP3). Dus daar heb je niks aan.
Kun je verder geen mp3's naadloos aanelkaar krijgen met een tracknummer zoals dat met waves wel kan?
Voor zover ik weer kan dat tot op zekere hoogte. Het zal nooit zo mooi overlopen als op een CD. Een vriend van me heeft de op 1 na duurste Pioneer autoradio met MP3 en daar krijg je het ook niet echt 100% naadloos in elkaar overgelopen. Helaas...
Dat is die Pioneer 7000 serie? Die is niet echt geweldig met het skippen van Mp3tjes nee.. vond ik zelf echt tegenvallen voor die prijs. Wellicht dat de 9000 serie daar geen last van heeft maar goed.. die gebruikt ook gewoon een harddisk
(en de prijs is er naar ja.. ) Ik was overigens zeer zeer onder de indruk van de Blaupunkt Daytona MP53 (met MP3 support), zag ehm voor 249 euro in Duitsland .. denk dat ik die maar ga halen.
Tja zonder pauzes die Mp3tjes skippen.. ik denk niet dat het gaat lukken zonder dat ik een compleet technisch verhaal gaat omhangen op dit tijdstip.
