maxi dauphine
maxi dauphine
Car: dauphine
Zijn zeker heel wat hier die mij wel kennen. Herman Pit heet ik en woon sinds 13 jaar in Zweden.Hier wat foto,s van mijn laatste projekt. Heb heel wat Renaults gerestaureerd en verbouwd door de jaren heen.
komt een motor van een Volvo 480 turbo in met 195 pk met een Williams bak.
Heb nog meer foto,s van het begin maar die zitten nog in mijn oude computer.
[img]http://i1380.photobucket.com/albums/ah1 ... nwzylx.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... eadsu5.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... ttzf8y.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... hxd7yt.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... kbvuei.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... 2sxc8q.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... nx261u.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... xq56yh.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... drakvx.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... jpewkz.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... ur8y33.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... soip3p.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... bbkoq9.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... jj1z04.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... 6xmt3h.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... xzpx5x.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... b3zyzm.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... sjj43a.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... vp9wi9.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... 11gtry.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... zaavt2.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... h2piin.jpg[/img][img]http://i1380.photobucket.com/albums/ah1 ... tmuuep.jpg[/img]
Gaatze
Car: 5AT,12TS
Welkom bij de RTC! (Y)
Erg gave Dauphine, getuigd van veel vakmanschap!
wow respect :kwijl:
Welkom Herman...
maxi dauphine
Car: dauphine
dank u. zal die andere foto,s eens een keer opzoeken, dan kunnen die er ook op.
heb 3 Dauphines gekocht hier voor 300€ waaronder een Gordini.
2 waren rot en deze had maar 57000 gelopen en was in redelijk goeie staat.
wat verrot was moest toch verbouwd Worden.
alle Dauphines hier in Zweden hebben een 4 bak dus heb motoren en bakken kunnen verkopen.
hele onderstel is verbouwd en en zitten subframes van een 5 GTE onder zowel voor als achter.
Boaz
Nou dit is het project waarop ik gewacht heb :smile: echt heel gaaf.
ben benieuwd naar het eind resultaat.
Geweldig :worship: Wat een project! Jammer dat je zo ver weg woont :( Deze zal wel niet zo snel op een meeting te zien zijn hier...
Daan2D
Car: M2GTRS + R25 + C3RS
I like! Ziet er echt heel dik uit met de maxi wielen eronder. Benieuwd hoe hij uitziet als hij klaar is.
Mooi project, welkom Herman !
ericon
Car: Meg RS225 + diversen
Welkom hier Herman (Y)
Renault grand Scènic Techline 2.0 16V - Renault 5 Alpine turbo - Renault Juvaquatre Dauphinose Break - peugeot 505GTI automaat.
maxi dauphine
Car: dauphine
duurt nog even maar als die klaar is neem ik hem mee naar Ommen of zoiets.
Wtf...?
:bang:
JDclio
haha.. wauw! dit is echt wel heel erg dik! :worship:
Waarom trouwens juist een 480 turbo blok? een speciale reden? of?
Ik denk dat juist veel mensen voor een megane 2.0T zouden gaan?
maxi dauphine
Car: dauphine
die kwam ik toevallig tegen kant en klaar met Williams bak en maar 300 km gelopen na revisie.
was ook van plan om er een RS motor in te hangen.
Misschien komt dat later nog eens.
moet eerst maar door de sfro keuring met deze.
www.sfro.com
Welkom Herman, erg gaaf project!
Zou inderdaad leuk zijn om hem hier eens irl te zien!
maxi dauphine
Car: dauphine
Zal nog wel effe duren.
moet eerst grotendeels in elkaar zodat ie voor de eerste keuring kan.
daarna uit elkaaar lassen bijwerken, stralen en binnenkant spuiten voor dat ie af gebouwd kan Worden.
en het is erg druk op het moment met de boten bouwerij.
https://www.facebook.com/pages/Aluminiu ... 7847212426
Leuk! Ik zit ook in de aluminium botenbouw: http://www.kmy.nl
Geert
je hebt het over een 480 turbo blok maar ik zie een f7 kleppendeksel?
maxi dauphine
Car: dauphine
heb lang voor oa Vitters en Gouwerok gewerkt. maar bouw nu tot 12 meter in eigen beheer.
Geert schreef:je hebt het over een 480 turbo blok maar ik zie een f7 kleppendeksel?
480 turboblok is een Renault 1.7 waar Volvo samen met Bosch een turbo op heeft gezet en het e.e.a. aan de internals veranderd heeft. O.a. zuigerbodemkoeling, andere kleppen, andere zuigers volgens mij.
Denk dat Geert meer bedoeld dat er een F7P/R kleppendeksel in beeld is.... :)
maxi dauphine
Car: dauphine
klopt die zit er nu nog in maar die 1,7 gaat erin.
die is omgebouwd met andere zuigers mm.
maxi dauphine
Car: dauphine
Bizar! Wat een project!
Dikke respect! :worship: :worship: (Y)
Cool! :worship: Hou ons op de hoogte! :p
Sven 5 A T (VLIEGTEUG)
Herman ! Leuk dat je hier ook bent ..!
Als die wielen over zijn geef ff een gil ;)
Die metalen verbreede staan toch veeeeeeel mooier;)
Kunnen ze mooi met die 2 wielen van mij mee terug naar Holland
maxi dauphine
Car: dauphine
nehe die wielen blijven mooi hier.
die 2 andere kan Harry wel meenemen die komt hier in April heen.
die stalen zijn voor het zondagrijden.
maar dan met een beetje meer tempo.
Je hebt de carbage weer overleefd zag ik.
Jup jup alleen mijn stem ligt nog in Zweden ... Dus als je die vind :grin:
Helemaal te gek dit project :worship:
Enige opmerking is ook over die motor, persoonlijk zou ik juist een atmosferische 2 liter pakken als een F7R/F4R met een paar throttlebodies erop, puur voor de betere driveability.
Al snap ik ook wel dat je bij de term Maxi, ook maximaal wilt gaan en dan is een turbo wel makkelijker. (Dan nog is een turbo op die huidige F7 schroeven ook niet zo gek ;) )
Welkom and keep the pix coming!
maxi dauphine
Car: dauphine
klopt, was ook eerst van plan om er een clio rs in te stoppen maar toen kwam ik deze tegen en die had maar 300 km gedraaid.
volgende projekt word waarscijnlijk een 17 gordini met RS motor
Zo'n 1,7 turbo is echt vele malen makkelijker dan een F7 ombouwen naar turbo. Die 1,7's zijn oersterk en echt zwaar ondergewaardeerd. Kan alles wat een c1j kan en meer....
maxi dauphine
Car: dauphine
Deze motor met Williams bak komt erin. 195 pk
[img]http://i1380.photobucket.com/albums/ah1 ... hcwted.jpg[/img]
:bang:
jankees
Echt, helemaal te gek project zeg (Y)
